warmech
A while back, I acquired a Macintosh Portrait Display that ended up only needing a re-capping to get back in working order. What I did not have, however, was a way to connect it to any of my Macs. After picking up some connectors from Mouser, I set out to make a cable to get my IIsi hooked up to it. The cable works, but it looks ugly as hell. So, recently, I set out to teach myself how to design PCBs and decided to start here with an adapter to just let me use a standard (and, most importantly, cheap) 15-pin display cable. The result? Well, first...
Old and busted:
New hotness:
I just got the PCBs in this evening and assembled what you see above... and it works great! The 13W3 connector here is waaaay too expensive (~$17) but once I get some less expensive ones I plan on selling these at basically just over the cost to build. I know there can't be that many folks that need a means of connecting their MPDs to a Mac, but for those that have a handmade cable that either doesn't look so great, or have a broken OEM cable, or are just missing one altogether, I figure this might be of use.
Old and busted:
New hotness:
