Test Classic II logic board with SE analog ?
emuboy
Good evening!
I recently acquired a Plus an SE FDHD and a Classic II, I recently recapped the Classic II but I wanted to test it before I start to recap it's analog board.
I have a fully working SE, I notice the connector for the analog board it's the same, can I just connect it?
robin-fo
I don‘t think so, at least one signal is different (brightness control PWM). Maybe you can rewire an ATX extension cable..
emuboy
So, I tried this and tested the cable before plugin it in, it has worked for a short while, but the image was reveresed and I had white horizontal lines on the screen, sadly, that was it, I shut it down quickly but now I don't have any picture on my SE with the SE board plugged in, I have 12v and 5v and I it does the booting sound.
The logic board was marginal so perhaps something has given up.
weird toh, why the signal would be so different?
emuboy
Ok, I don't understand what happened but my SE is fine, took it apart, put it back together and it was good to go, clealy it wasn't happy about the video signal.
