Ten Years Later...
iMac600
...still as unusual as ever with my thread titles. This one holds some relevance though.
Some time in 2004 is when I sold my PC and bought my first Mac. This year marks 10 years since then, and oh what an interesting ride it's been. It was also the year I first encountered what would become almost a mythical creature in my book. I missed it by a few hours and a few dollars, and since then, I'd been looking for another one of these Macs, finding some examples that were priced out of my range, or too far away to collect. Then, recently, one finally fell within my reach.
I'd like to introduce you to my Macintosh Colour Classic. |)
With their rarity, I couldn't be selective about the machine I bought. It's probably just as well, because this Colour Classic - while well loved - was also well used.
This machine needed a deep cleaning before anything else. So the entire machine had to be stripped down, including the removal of shielding from the Analog Board and Chassis. Every inch of the machine was sprayed and brushed clean. The Floppy Drive was seized solid, and rather than attempt to repair it, I replaced it with a freshly refurbished one I'd prepared a few weeks earlier.
Every battle scarred machine has injuries that need to be attended to, and this machine had its fair share. With the assistance from a powerful metal and plastic adhesive normally used for moving parts, several plastic tabs were reaffixed to the front bezel. These won't be coming loose any time soon.
The CRT was horribly misaligned, with poor convergence and geometry. Some resoldering of the wires and connectors on the Analog Board, Neck Board, Flyback Transformer and Yoke connector was required. Most of these solder joints are rather clean, with the exception of a couple on the Neck Board that require further attention. The Focus was reduced as it was turned much too high. The Geometry was adjusted to bring the raster into line, and then with the assistance of Larry Pina's Color Test Pattern Generator, the Convergence was bought into line. One of the Convergence Strips was reaffixed to the tube, but requires a more heat resistant material than I currently have available.
All of that work brings you to the picture you see at the top of this post. :D
It's not without its flaws still. There are still some minor nicks and chips around the seam, and there is an Apple logo on the side of the machine where a sticker used to sit that has allowed the plastic below to yellow at a different rate. The Power Supply and Logic Board are due for a capacitor replacement, and some of the internal components will require some attention in the near future, but nothing incredibly major.
But this conquest wouldn't be complete without bundled software, which is almost as thrilling as the machine itself. Among the lot are boxed copies of ClarisWorks, SuperPaint, Lemmings, Disk Doubler and Macintosh PC Exchange, standalone genuine disks for Adobe Photoshop, Kid Pix, Print Shop, two versions of Norton Utilities, At Ease 1.0, System 6, System 7 and the restore disks for the Colour Classic. Perhaps most exciting for me is the boxed copy of SimCity 2000. There's a lot more here, at least a couple of hundred disks, but I still have to take inventory.
SG3070A8C2J
Manufactured in: SG => Singapore
Year of production: 1993
Week of production: 7
Production number: 0A8 => 348
Modell ID: C2J => unknown Mac
Your unknown Mac was the 348th Mac manufactured during the 7th week of 1993 in Singapore.
This machine came with a companion, which I was equally as thrilled about. I'll let that machine have its own post below though.
Cheers,
~ Mic.
iMac600
With the Colour Classic came a Macintosh 512Ke.
Inside, this 512Ke differs from the other one I have. The inside of this machine is silver metallic, while the other machine is flat grey and black. The CRT is a Samsung, not a Clinton tube. The Analog Board makes use of red capacitors as opposed to the traditional green and blue, and the plastic shield is held on with plastic pins where others I've found used double sided foam tape.
After making a CRT Discharge Tool, I removed the back and the plastic safety shield on the Analog Board and resoldered the Flyback Transformer and the connector blocks to the Analog Board. This cleared up the CRT flicker. After that only the Centering Rings needed adjustment. Compared to the Clinton CRTs, these Samsung displays are ridiculously easy to adjust. I already had an 800K Sony Floppy Drive with fresh grease on the tracks, so I swapped the old drive out rather than opting to repair it immediately. I'll fix the old drive eventually and reuse it in another machine.
F7262KGM0001ED
Manufactured in: F => Fremont, California, USA
Year of production: 1987
Week of production: 26
Production number: 2KG => 2974
Model ID: M0001ED => Macintosh 512Ke
Your Macintosh 512Ke was the 2974th Mac manufactured during the 26th week of 1987 in Fremont, California, USA.
Other than some minor scuffs on the surface of the CRT, it looks fantastic inside and out and it works quite nicely for a 26 year old machine.
unity
Thanks for sharing! The CC is indeed a hard one to grab it seems. One of my friends has a CC II!
I did not know that the later 512ks had metallic RF paint applied like that. Good to know!
iMac600
It's called Tarzan's Grip ShockProof (or ImpactProof) super glue. It's a rubber modified adhesive, so it's a lot more resistant to bending and impact stress. I've used it to bond together broken magnesium frames and Unibody MacBook Pro displays, and it works surprisingly well considering the stresses it's subjected to.
uniserver
it funny i haven't seen you on in like 6 months then you write up this fantastic post.
Great job on the CC buddy.
- it now looks like brand new.
I wish everyone would make posts like yours, including my self.
I like reading into the story of the machine!
i find it very interesting.
iMac600
I stopped visiting here around the same time I resigned as an Apple technician. I had and still have a lot to think about, but recently I found myself wanting to share some of the developments with the others here. Apple collecting is a rather low priority for me these days, but while I don't actively seek out machines, I still receive and repair damaged units from time to time, and I always keep space on my shelf for the few notable machines I'm particularly fond of. That, and I still like to experiment and share what I know and find with others. A former technician turned teacher, if you will. :)
So, it was only inevitable that I would be back eventually.
I have a couple of more threads you may find interesting in the works. Keep lookout here in Conquests and in the Apple I/II/III forum. :D
