tashtari
PIC Whisperer
Oh, sorry, thought I had posted this already... it's from SparkFun: https://www.sparkfun.com/products/13743Where did you buy the 7pin SD card reader?
The HD20 doesn't have media, per se, to eject. I really hope someone on here wouldn't mind taking a stab at it. I would LOVE to have a Floppy adapter that enables daisy chaining by converting a FDHD into a block device. This would be a dream come true.Update: It is possible to eject a DCD that has the ejectable flag set, but it comes right back immediately, and there doesn't appear to be a command being sent that could mean "eject media" or anything similar. The only thing I wonder about as I look at the trace is that sometimes the byte after the command byte in the Controller Status command is 0x00 and sometimes it's 0x01. I don't know what the significance of this is. It'd be a weird way to ask the drive to eject, but that doesn't rule it out. If there's an answer to this question, it probably lies in the depths of the driver code. BMOW posted a decompiler listing with some comments, though damned if I can make much sense of it. Anyone care to dig in?
This is true, but the DCD specification was meant to accommodate storage devices of all types, and there's an "ejectable" bit and a "disk in place" bit in the Controller Status response, which suggest that removable media was considered too. In that case, though, I'd expect that there would be a command sent to a DCD that was listed as "ejectable" to eject its media (after which "disk in place" would read 0) but I set a TashTwenty up with these bits set and watched the bus traffic and didn't see one. It could be that it was just never implemented in the ROM, but I can't say for sure because reading the ROM code is an exercise in self-induced headache...The HD20 doesn't have media, per se, to eject.
10 kohm is what I used, it's a pullup resistor for the MISO line from the card.What are the values of the resistor (10 kOhm?)
10 uF is what I used, it's a decoupling cap across supply and ground. Make sure you get a low-profile one so there's room for the SparkFun board to fit over it.and the capacitor?
If there's enough interest, I could see getting a few of my design made for sale, but @demik was working on one as well and may be in a better position for it than I am.Will assembled boards be available in some (near?) future?
I would. If price is reasonable, I would consider a couple units.If there's enough interest, I could see getting a few of my design made for sale, but @demik was working on one as well and may be in a better position for it than I am.
Is anyone else interested in buying? If so, please let the thread know. =)
Wasn't the HD20 an MFM drive?The PC 5.25" was basically a standard shugart interface drive in a custom Apple case. The interface card had a NEC PC compatible MFM controller on it.
Me too.I would. If price is reasonable, I would consider a couple units.
There are some sellers on ebay, or you can order them from IEC, which has the world's worst online store (I just ended up calling them).One problem may be getting the 19pin DB
Oh ok. A bit confusing. I assumed it was only a method by which to connect a device like SCSI or IDE.All MFM really means in this context is the way that the data is encoded as magnetic transitions on the disc surface. It doesn't mean that anything else is common about the mechanism of the drive or the way it communicates...
