falen5
Hello to all the Mac fans from Ireland.
Been gone for 2 or 3 years now. Its my eyesight. It has gone so bad I just can solder, or work on boards anymore - not that I ever had a clue what I was doing anyway.
Big hello to technight and everyone else who helped me so much on here.
Anyway
I took down my TAM to sell it. Only to find (or rediscover) that the CD player was not working too good. I just fixed it and its working perfectly.
Problem : You put in a cd, close the door, the cd begins to spin up and then the laser starts making all kinds of crazy sounds, clicks, grinds, etc etc for ages and ages. Eventually the cd icon appears on the desktop , but you still cant do anything - playing audio cd results in long pauses and noise in the audio.
Having cleaned the laser lense i discounted that.
You can fool the tam into thinking the door is closed by pressing the little silver switch on the left side of the bay, towards the top. This starts the laser off... moving, focusing, left , right, up , down etc etc. That seemed to look Ok to me.
Then i put in a cd and did the same. CD spins up and then the laser starts its wild movement all over the place.
Still could not see what the problem was.
So I started to wonder about the height of the CD from the laser.
HERES HOW I FIXED IT.
I carefully removed the black , plastic, center spindal that the cd sits onto. I did this using 2 small screwdrivers, levering from opposite sides - carefully and gently and it pops off.
I then cleaned the old rubber that had basically liquified ( its the face that the CD sits onto) - i thought this old rubber was causing the cd to "sit" to high above the laser.
Put it back and tried again , but it still did not work.
I carefully looked at the gap between the cd and the cd bay and decided there was a small amount of room to "lower" the cd closer to the laser.
So I took off the spindle again, got some fine sandpaper on a flat surface, sat the spindle on the sandpaper, cd side facing up, and removed just a tiny amount of plastic.
The point is to try get the cd a tiny bit closer to the laser.
Well feck me blue and call me a blind paddy, i put the spindle back and my CD player is working perfectly.
Dont know if that has been discovered before - I just discovered it for myself and thought Id share it for anyone else with the same problem.
God Bless people
Anyway
God Bless people
