commodorejohn
Well, I recently came into possession of a nice little Mac IIsi. It's in nice shape and runs fine, and some previous owner put a whole 16MB of RAM in it (plus the 1MB on the motherboard,) so I should be comfortably set for some 68k goodness :approve:
...or so I thought. I got System 7.5 installed from the disks that came with it and got some software copied over. Problem is, System 7 is taking an absolutely ungodly amount of RAM, leaving about 6.5MB of the 17MB free for applications. I spent a while disabling unnecessary features and extensions and got it down to a much more reasonable 2MB. Problem solved, right?
Wrong :-/ For some reason, the changes didn't stick, and it's back to loading every damn thing into memory. I tried disabling things in the Extension Manager, tried moving them to a separate folder, no luck. I don't want to just delete them because most of them are things I might want later on (networking and CD drivers, for instance,) but 10+ MB of RAM chewed up by the OS just isn't acceptable.
The PRAM battery is either dead or dying; I'm not sure how or if this would factor into it, but maybe? I don't know. Can anyone help me figure out how to address this?
