System 6 extension/control panel to modify keyboard input?
Frobozz
I'd like to make my Mac Plus more useful/pleasant-to-use. I use an original mac 128 keyboard on it, not the bigger Plus keyboard. So: no cursor keys! I have used a mac (original) keyboard on my modern macs with an adapter. I can program layers/etc and basically set up cursor keys that fire when caps lock is held down (for example). But if I want to do that same on compact mac hardware, I don't have a hardware based thing in between with firmware I can modify.
I was thinking about ForwardDelete68K, which lets you do shift-backspace to get a DEL key. Some programs that modify key input:
I've done a little System 6 app programming in the past, and thought this would make a fun project to try with retro68. Thing is... I don't have the first clue what I'd be doing here. Does anyone have a pointer for the general theory I'd be trying to execute? Or whether this is even practical? I assume it will have some limits, based on how ForwardDelete works (I think only apps that rely entirely on toolkit calls respect it).
I'd like to try caps lock turning +/= into up, [ into left, ] into down, and \ into right. On the 128 keyboard, those are very close to an inverted T, and near the backspace key, which I tend to need a lot.
Crutch
You would need to write an INIT to patch a trap, which is doable but sort of an advanced topic in System 6-7 coding that requires some care.
I would suggest patching GetNextEvent and WaitNextEvent, which most apps will call to get a keypress.  I would simply patch them to do their normal thing then, if they are about to return a keyDown or autoKey event that looks like Caps Lock and + or whatever, to instead return the character code for the arrow key you want.  This is a “tail patch” which can theoretically introduce incompatibilities for technical reasons, but you are probably fine.
The whole thing is probably 80 lines of code.  I can offer some more specific details if you’d like.
Frobozz
Thanks Crutch, that was just what I needed.
I haven't used it enough to see if there are stability issues, but it seems to be ok so far. I did notice some apps (e.g, MacWrite pre-II versions) don't do anything with the cursor actions, but I'm not 100% sure yet that they would react to real cursor keys. Wouldn't surprise me, as I was surprised by having keyCode = charCode in the EventRecord. The key codes listed in Think C reference for Mac Plus/etc aren't returned at all (at least for the keys I tested).
Some links that I found helpful in case anyone stumbles across this in the future:
Frobozz
I can't believe how much time I spent today and yesterday basically trying to do one thing: move a 2K system extension from a Mac Plus over to my modern Mac so I can upload it here. ;)  Ah, well. I now have a SCSI2D and "Serial" app with a null modem connection to the Plus, so it hasn't been a total loss of time.
What this system extension (INIT) does:
  • When caps lock is down, turns [{ key into left cursor, \| key into right cursor, =+ key into up cursor, ]} key into down cursor.
Why you might want this:
  • You have an original 128/512 Mac keyboard and wish it had cursor keys
  • You have a Mac Plus keyboard, Apple Desktop Bus Keyboard ("IIGS"), M0116 (II/SE "standard keyboard"), or Apple Keyboard II and wished you had cursor keys in an inverted T arrangement
How to install this:
  • Get it onto your Mac somehow
  • Expand the .SIT file
  • Drop the INIT/extension on your system folder. For System 7+, the Mac will further drop it into your System Extensions folder
How to use it:
  • Engage caps lock key, and use [, ], \, and = as cursor keys
  • No other keys are affected
Does it have a Control Panel?
  • No. Nothing is configurable, in the interest of keeping size to a minimum.
Which systems is it compatible with?
  • Good question. I have tested so far with:
    Mac Plus with 128/512 keyboard running 6.0.8 (US)
  • Mac Classic with Apple Extended Keyboard running 7.1 (US)
  • Sheepshaver (OS X) running 9.0 (Japanese)
[*]If you test it on another system, please let me know if it works or not. I would expect it to not work perfectly for any language/country that has a different arrangement in that part of the keyboard.
Will it work in all apps?
  • No, but it should work in all apps that are well-behaved, and which actually have some kind of cursor-based behavior. I noticed in testing, for example, that MacWrite (pre-II versions) didn't do anything with the cursor input. I tried MacWrite with a Mac that had native cursor keys, they didn't do anything either! Your mileage may vary.
Why didn't you map IJKL?
  • IJKL does make a better inverted T for cursors, the but problem with that is that you basically can't use the keyboard for any typing at all when you are in that mode.
Can it do my homework?
  • Not currently. All it does is map 4 keys. If you have any idea for other keys, I'm not adverse to mapping more. The only concern I have is that the more keys that get remapped, the more the hit on typing performance might be noticeable. I didn't do any testing though, so it's possible it's not a concern. I'm sure it wouldn't be on anything faster than a bare 68000. I am thinking it might be bad to unmap all the caps lock capitalization, so you could basically run all the time with the caps lock engaged, and only undo it when you need [, ], =, or | (which, unfortunately, as a programmer, is pretty much all the time!)
Version 0.1.1 attached
View attachment CapsLock Cursors.sit
Crutch
This is super cool, I am excited to check it out later.  What a useful idea.  I dislike the Plus keyboard (always found them funny looking) but use them because I feel like I can’t live without cursor keys.  You have solved my problem for me in a way that never occurred to me.
What development platform did you use to implement it?  I think you could implement most of your ideas for enhancements with no performance hit.
You linked some very nice resources there.  The “Writing INITs from THINK C” from MacTutor is a classic, but I’d never seen the Apple doc you linked on the Trap Manager before.  Well researched.
Frobozz
Ok, found a dumb bug that explained my confusion about the keycodes=charcodes.
This version de-capitalizes alpha keys too, so the idea is the user can just leave caps lock on until they need =, [, ], \.
I'll get a GitHub up soon, but I threw the source into it for now. it's a Think C 5.0 project. (I was having so many other futsy old computer issues that Retro68 went by the wayside in the name of getting something done).
View attachment CapsLockCursors_v0.2.0.sit
Crutch
Agreed, code looks like a textbook trap patching INIT, nicely done.
You said it works in 7.1 which is interesting because you didn’t patch WaitNextEvent.  I wonder if WNE calls GetNextEvent, so you get a WNE patch for “free” under System 7 orMultiFinder?  It would be easy to check I suppose ....
Frobozz
That's a good question. I guess my assumption is that WaitNextEvent has GetNextEvent in its own call chain. But another possibility is that the very few apps I tested with hadn't been written with WaitNextEvent, but were still doing GetNextEvent. Seems unlikely, but I suppose it's possible.
Trash80toHP_Mini
NIGHT STALKER
Did a quick skim of the topic, so please forgive me if this blast from the past is irrelevant to your System 6 project:
Does any part of this resemble anything like what you're trying to achieve?
Frobozz
Yes, it's the same concept. I did look at the resedit path, but I wanted something like Forward Delete, an extension I (or others) could simply remove if they didn't want it, and add it back if they did. Also wanted to learn how to make an INIT. The same exact code, with a few more conditions, could do what you have above. It would need to be a lot bigger to be able to read preferred keymap from disk, and even more to have a GUI for switching keys, and this is for Mac Pluses and 512s, so every byte is bit precious.
That photo makes me want to drag out one of my PBs. but I have very little confidence either of them would start up. <sigh>
