Solid State Drive (SSD) in SE/30
johnklos
At least temporarily. Acard has flash update programs for Mac OS 9 (maybe 8.6, too), but not for OS X. However, the program to update the SATA-SCSI devices is apparently Windows only. I only upgraded mine because my drive kept spinning down way too often and the newer firmware fixed that.
jellyfin
It worked! I can boot system 7.5 off of the ssd now. Fantastic. It's a bit pain having to have about 800000 partitions though. :p
johnklos
Glad to hear! That drove me crazy for weeks. By the time I thought I knew for certain what it was, the 30 day Windows eXtra Poop activation grace period was up, so I had to reinstall Windows to try the different firmware... Worth it, though!
paws
The base reference is a 5400 RPM 300 gig Hitachi HTS54323 2.5" SATA drive connected via an Acard ARS-2000SU SATA to UltraSCSI adapter / case.
Hello! That's exactly the kind of thing I want. Where did you get it and how much did you pay?
johnklos
When I first bought them, they were around $150. For a while they weren't available for less than $200, but it seems the price is a little more reasonable now, back to what I paid:
http://www.google.com/products?q=ARS-2000SU&aq=f
I had a 250 gig 7200 RPM Seagate in one for a while but only because I wasn't using it for anything else. The drive eventually died; not sure if it was because of all the stops and starts (which is why I updated the firmware) or something else, but there's absolutely no speed advantage to a 7200 RPM over a 5400 RPM. On slower machines the rotational latency difference will easily get lost in the noise.
johnklos
Ha ha ha... If you're running Mac OS 8.1, you can have one partition at the beginning from which to boot, then use the rest as HFS+. On the other hand, I'm running NetBSD, so I just have a 500 meg Mac partition with System 7.6.1, a NetBSD FFS partition, and a swap partition. The drive now, BTW, is a 320 gig SATA. You can hardly find smaller drives these days.
paws
A few of the online retailers here list 4 and 8gb SATA SSDs, not cheap (certainly not for the amount of space) but not completely out of reach either. I would like to try this but I'm not sure I will ever get round to it...
