reject902
Hey everyone.
I thought maybe we could start a thread with the Software Update logs from Mac OS 9 on up. Since Software Update has been disabled for Mac OS 9 - OS X 10.3, I thought maybe we could get something going that shows what updates we had on our setups installed via Software Update. That way, anybody coming late to the game or doing a fresh install will at least have an idea or starting point for the software updates that exist.
So, if you can help, go to
In OS 9.0-9.2.2:
[VolumeName]/System Folder/Preferences/Software Update Logs
In OS X:
[VolumeName]/Library/Logs/Software Update.log
Grab the text from the log file and post it in a reply to the thread along with the OS version number you a running and your machine model. Use the code function to paste the log text in the thread--that way the posts don't get crazy long. If you're running an OS X set up and iLife is installed, reference what version of iLife you are running.
As the thread builds, I'll edit the main post and list the OS version reported along with the name and version numbers of the updates that Software Update had applied. This will probably end up being most useful for OS X 10-10.3, as there were a lot of updates that came through Software update.
Thanks everyone for your help!
:beige:
In OS 9.0-9.2.2:
In OS X:
:beige:
