I did a bit of a preliminary sort on what I had on hand for the osx-sw section - it's gone a
little out of scope within the Apple section, but I'm amenable to placing whatever people think will be relevant to hold onto.
One thing to be aware of is that where possible, we will want to grab multi-lingual versions of things. (i.e. when we go to pull down Firefox 2 or 3 whatever, we should grab it for every language.) We can decide how to sort that later, but AFAIK most of these companies have the same names everywhere so it would make sense to me that we either do language folders inside a version folder
(For example: Mozilla -> Firefox -> 2.0 -> 2.0.20 -> EN-US -> firefox20.0.20-en-us.dmg) or that we just stick all the builds for a version in a folder (for example Mozilla -> Firefox -> 2.0 -> 20.0.20 -> firefox20.0.20-[lang].dmg where there'd be 38 or whatever builds and one is en-us and another is se-sv and another is en-uk and ca-fr and so on).
OS X era Apple is pretty good on this front in that
most of its software installers are multilingual.
The other thing I haven't put in here is documentation or notes files. For example, if I have a serial number for Fetch, I might put in a file that says "Fetch Readme". The readme/doc files, I imagine, should have a standardized-ish format but I haven't gotten too far on what that should be, if anyone wants to throw out some ideas I'd love to hear them, and ideally will have compatible OS versions listed. (Fetch 5.7 for example is a release that works on, like, Sierra, so it's a
little out of scope here but I had it on hand and it's not too big.)
The other decision, and this will probably be ad-hoc and per version, is to decide how granularly to organize things. i.e. for Fetch should those all be together in Fetch 5 or should they each be in folders for Fetch 5.X or should they be in folders split by Fetch 5.X.Y.
Also, I'm working on getting the macgarden_incoming share up, I wanted to put the data on a slightly more robust purpose-built external disk, instead of having the internal disks rattling away in the toaster.
