Anyone know the Socket Size for the Video Memory on the SE/30
MegaImg Well-known member Jul 20, 2023 #1 Anyone know the Socket Size for the Video Memory on the SE/30
C Chuckdubuque Active member Jul 20, 2023 #2 There's this BOM from @joshc for @Bolle's SE/30 reloaded board. Not sure if it is an exact match for the original board: https://docs.google.com/spreadsheets/d/1CAzGjHxQaQrduQC-hQ8sB2I6Y56fUlCWdJMCUDho0NE/edit#gid=0
C Cam Well-known member Jul 20, 2023 #3 Is that the weird width socket? I ended up cutting a normal sock length wise and putting the pieces in individually. Probably could have used pin headers the same way, but didn't have any in my parts bin. I really need to get back to that project . . .
teemaw Member Jul 20, 2023 #4 This is the Mouser part I used which worked for me: https://www.mouser.com/ProductDetail/437-1158742441003101
MegaImg Well-known member Jul 21, 2023 #5 teemaw said: This is the Mouser part I used which worked for me: https://www.mouser.com/ProductDetail/437-1158742441003101 Click to expand... Thanks!
