SE/30 VIA chip replacement
MegaImg
Already did, Building a new Logicboard, Will try them! Almost all the IC are new, Loking for a damage board to finish it!
codevonlux
I recently worked on a SE/30 Reloaded board. The ADB chip from the donor board is bad so I used a PIC16F87 replacement ADB on this board. (mentioned here: https://68kmla.org/bb/index.php?threads/mac-se-adb-controller.38363 , with a QFN-to-PLCC adapter PCB by max1zzz).
I noticed that if I use W65C22N6TPLG-14 as VIA1 then it is not compatible with this ADB replacement, the mouse movement is sluggish then finally hung, death chime also happens from time to time during boot. Same VIA1 works fine with original ADB chip and Original 65C23 works fine with this ADB replacement.
I guess there might be some timing issue becuase it was mentioned in the ADB thread that the original 3MHz clock is not used in the PIC16F87 and it is running faster than the original ADB chip.
plexxer
I am working on restoring an SE/30 that functions great aside from the ADB devices - the mouse is barely responsive and the machine seems to not boot when the keyboard is attached. I did a recap (the sound started working!) and it didn't seem like there was any leak damage, but looking more closely I did spot some green-tinged areas on the edges of UK11 65C22 and I believe the IC has become compromised.
The problem I am having is finding a source for the NMOS replacements. Mouser is out of stock of the W65C22N6TPLG as is any other distributor I try. My searches for the R65NC22J4 have also come up empty. Does anyone know where I can obtain a suitable replacement?
djc6
A group buy for SE/30 reloaded boards had a nice BOM attached. Here is the thread: https://tinkerdifferent.com/threads/so-you-wanna-start-an-se-30-reloaded-group-buy.2936/
Here is the BOM: https://docs.google.com/spreadsheet...bEiThW19gc/edit?gid=1837251752#gid=1837251752
It mentions this supplier for a used one: https://www.utsource.net/itm/p/1073631.html
Same part number 338S6523 is mentioned in 2nd post of this thread.
plexxer
Thanks to both of you for your help. I ordered 2 338S6523 from that outsource.net. I would have ordered a few more but I didn't want to get a surprise tariff bill. The reason I am working on all of my old on-hold projects is to limit my ordering from overseas!
plexxer
My problem turned out to be a bad fuse. Not sure why I didn't check it first - I think the fact that there was still -some- mouse movement along with the corrosion led me to believe they were faulty.
croissantking
Hi!
I bought a couple VL65C22V-02QC from here: https://a.aliexpress.com/_EuQvcl8
It’s the same part number as the original chips in my board. But sadly I can’t tell if they work because my board doesn’t boot neither with these nor with the original ones.
Mine arrived from the same link you posted, just finished testing them out and they work great. They’re not remarked and they have 338S6523 printed on them, indicating they’re harvested from Macintosh boards.
demik
Sadly it looks like those WDC chips are out of production.
Only the W65C22N, the W65C22S is still produced in PLCC form (for now). I've tested one in a 512ke bench board, it works fine except reading the 1Hz tick from the RTC. It isn't behaving as expected. Think it's juste one pull-up away but didn't had time to test it
Don't have any SE/30 bench boards around tho.
