I bought an SE/30 that if I let sit awhile or gently addjust the video board it will will boot up from floppy.
It was sold as not working but when I got it it booted up from SCSI to 7.1 and had MS word installed on it a few reboots/days later it slowly degraded to no SCSI device found and then to SimasiMac.
I have it partly taken appart so far.. SCSI drive is out and I tried connecting some of my other drives (a 2GB barracuda, a 4Gb quantum and a 143Gb SCA with an adapter for kicks) ended up with the same issue it could be that I am not using the patched drive setup? The original drive was a 40Mb model and it still sounds perfectly good (I hear it spin up and hear the heads move) when booting up the mac just can't see it.
Now I have gotten variations of SimasiMac.. from grey to horizontal bars. They don't always occur.. seem to be less likely if I turn it of a bit adjust the analog board and try again sometimes there is a delay between the video appearing and the system coming up. It also eventually locks up after awhile of running even if it does startup correctly.
I do have a new PRAM battery haven't put it in yet since I don't have the logic board out yet. from what I can see with the board still in there it looks clean with the exception of all the caps being hot glued. Also the transfomer at the top of the analog board has hot glue on it.. no glue on video board.
I've booted 6.0.8 and 7.1 from floppy... and can have my PC setup to modify some floppies for testing.
I don't have a way of grounding the CRT so don't want to do much till I take care of that? what would be the safest way to do that... I hear turn brightness up and jerk the mains out of the wall ... or make a grounding kit with a screwdriver and a the center pin of a power cable being sure it does not ohm between the other two pins as a cheap cable would.
