Quick status of the system:
Logic board recapped, UE8 replaced, at least one trace from SCSI chip (D31) repaired with a bodge wire, ASC removed, cleaned, re-soldered, no-leak battery but replaced with CR2032.
Analog board connector (J1? the one that always gets hot and melts/discolors)—had cracked solder joints—reflowed these. Replaced fan.
The mac is working fine now, but it has been a long road of learning and troubleshooting. However, all throughout this process, the screen has occasionally exhibited a horizontal shimmer. When it happens, the display width contracts slightly, horizontal lines wiggle very quickly. I think I hear some static noise while this happens for a second or two, then the image snaps back clean and solid.
As I mentioned, this has been going on from the beginning, so I think my troubleshooting to get the mac working again has neither created, nor corrected this problem. I suspect it is still some issue I have yet to correct and add to my list of accomplishments! How’s that for taking the right attitude?
So, what’s going on here? I have not reflowed the entire analog board—yet, but I also am considering recapping it. I could also look at the CRT neck board or the PSU, though power tested OK at one point. Thoughts? It does seem to be getting more frequent now as I begin to “use” the mac more (reinstalling the OS, connecting to AppleTalk to transfer files, RaSCSI etc.). Attaching a video:
View attachment FullSizeRender.mov
