SE/30 ROM
jwse30
So I am getting ready to install a Daystar Accelerator in my SE/30, and am wanting to install a 32 bit clean ROM while I am in there. Are any of the new ROMs able to be flashed to mock a IIsi or IIfx ROM so the accelerator will work with it?
Thanks, and Merry Christmas!
J White
jwse30
My understanding (which does not make it fact) is that to use the Daystar accelerators in an SE/30, you can't use a modified ROM. I am hoping someone out there made one of the new ROMs that can be flashed to duplicate a IIsi or IIfx ROM.
J White
eharmon
A GGLABS MACSIMM or PurpleROM will work:
With a minipro/TL866 and PLCC socket adapters, they're flashable to standard IIsi ROMs. I've been meaning to make a tutorial, maybe I'll get around to it during the holidays.
EDIT: @olePigeon Also has a patched ROM which, IIRC, should keep the ROMinator features without breaking 040 support: https://68kmla.org/bb/index.php?threads/custom-bootable-rom-images-for-bmow-simm.30420/#post-324362
Nixontheknight
A Rominator ii would also work
