I assume you mean the neck board; I already checked every single component on that one, even replaced the transistor, but that didn't help. I also haven't got another one, so it is quite difficult to swap them. ;-)because i get that same screen , when the video board goes bad with the se.
Found a nice datasheet here: http://pdf.datasheetcatalog.com/datasheets/270/334520_DS.pdfPull the datasheet of that ic and make sure all your truth table conditions are met first...
Yeah, aside from a lot of probing and measuring those two things finally did it.hey man good find.. so pin 10 on the Vrom to pin 4 on the UD8, man your cap goo must have been extra bad!
so you think this and the I/C you replaced and this bridge wire from vrom was the fix here?
That's great to hear!i just fixed SE/30 just now with a dead 74LS166
the cap goo seems can short them out… and they go bad.
