techknight
yup you got a bad resistor on there.
The one on the neck-board seemed to measure fine, but I ordered a couple of new ones, just to be on the safe side.how about the transistor. i think that is the item that goes bad.
Thats not anything. That is just noise. Your missing the video signal. A real signal is much greayer in amplitude, but it also contains the video signal for a line and has a front/back porch inversion.I was wrong on the fuzzy line stuff, I just hadn't set up the scope properly for such small data.This is what I got directly on the logic board, probe on pin 13 of the UG6 IC, the video data output:
The signal isn't all that strong, only around 100mV P-P.
This is the signal on the inputs of the 74LS38 IC on the analog board, due to a couple of resistors on the logic board, the amplitude is a bit less than the output of the UG6 IC, around 70mV P-P.
On the output of the 74LS38 I get the 1.5VDC, so I think I'll try the spare logic gate, maybe that one will work.
Now that's some useful info! I'll check the power rails on the UG6 IC and linked components, maybe it just doesn't get its juice.Thats not anything. That is just noise. Your missing the video signal. A real signal is much greayer in amplitude, but it also contains the video signal for a line and has a front/back porch inversion.I was wrong on the fuzzy line stuff, I just hadn't set up the scope properly for such small data.This is what I got directly on the logic board, probe on pin 13 of the UG6 IC, the video data output:
Here's a quick pic:can you post a picture of what is acutely displayed on your se/30's CRT?
