aplmak
Question on blown fuses on SE/30 boards.. are those 1A fuses “slow acting” or “fast acting” fuses?? I’d like to replace with the same type.. but I’m not sure which one is “the proper” replacement. Can anyone comment? The current one was a BUSS orange in color 1A fuse. It appears the orange in color type are “slow acting” and green seems to be “fast acting”
I’m just trying to avoid on constantly replacing it if I get it wrong..
(Found a small piece of loose drifting solder under a smd chip, I got it out)
Thanks gang!!
Thanks gang!!
