After excellent dealings with Trag, I replaced (paid technician) to have caps replaced with tantalums. Fixed problem, but now focus is off a bit - but too uncomfortable to view. The Focus Adj. pot does nothing. Asked Trag, and in a most timely answer he told me it was probably fixed resistor.
He wrote: "If the focus is poor and adjusting R27 does not help, then most likely R26 is burned out (open). R26 is a 1 M ohm, 1/2 watt 5% resistor on the analog board."
Has anyone else had this problem on SE 30, and can you confirm what Trag said?
If you reply to MLA, can you also please send to?:
garygphotog@shaw.ca
I'e been having A LOT of trouble logging into MLA.
Great Thanks
Gary Greenspoon
garygphotog@shaw.ca
Great Thanks
Gary Greenspoon
