So i have a scsi2sd ver 5.1 and im just trying to get my classic II to boot up. i have been following the guide at http://www.savagetaylor.com/2018/05/28/setting-up-your-vintage-classic-68k-macintosh-creating-your-own-boot-able-disk-image/#comment-9111 (more info about the issue in the comments section of that page I am Michael) but no matter what i try when i turn on the mac i just get the disk icon with a "?". a brief overview (more info in that comment section) I set up the sd card with scsi2sd util (termination is set to off as it is internal), flash the OS to the card using balenaEtcher, both flash with no issue. put it in to the adapter and turn the mac on but no joy. I had read in a few places that the power to the board should have the 12v line cut so i had done that to the molex adapter but i also tried unplugging that and powering from usb but no change. with both power sources the led on the board will light up once when the machine is turned on but then goes out which is different when i hook it up to the pc, there it will flash every few seconds. not sure if that matters but figured i would mention it.
