jdlanza
Hi all,
I'm hoping to get your thoughts on the following. I'm refurbishing a PowerMac 6100/66 (DOS Compatible). Yanked the hard drive and replaced it with a SCSI2SD v5.1. Initially formatted the SCSI2SD as 4 4GB devices @ SCSI ID 0,2,4,6 and loaded 8.0 from an official install disc. Dropped it in. PowerMac got past the Happy Mac and then immediately throws a "bus error."
1. Replaced the ribbon cable. Same behavior.
2. Reconfigured the boot drive on the SCSI2SD to be 1GB only. Same behavior.
3. Reconfigured the boot drive on the SCSI2SD to be 16GB (only 1 device). Same behavior.
The machine will boot from a SCSI2SD v5.5 (the dongle) quite happily and will boot from the CD-ROM, with or without the v5.1 SCSI2SD installed. The machine also boots quite happily, with the v5.1 SCSI2SD board installed in the SCSI chain, as long as some other volume is identified as the boot volume. In that case, I have mounted disk volumes all over the place!
I'm left scratching my head at this point. Any thoughts appreciated.
johnl
johnl
