I cannot get my powerbook 540c (OS 7.5.5) to boot from a specific SCSI ID even when trying to manually select at boot (Command-Option-Shift-Delete-#).
I have two different system drives on the same scsi chain, but it will always boot from the drive with the higher SCSI ID.
If I manually change the drive IDs it will boot correctly, but this is inconvenient to accomplish as I use the drive on another machine that would need to be switched back every time.
Can I manually set the boot SCSI ID in software?
Thanks!
Thanks!
