SCSI harddrive for my LC III?
macgeek417
My LC III's harddrive is waaay too small, so could anyone point me to an ebay auction for a compatible scsi hard drive? i can't seem to get any results.
Gil
Search for "SCSI hard drive"
Anything with a 50 pin connector will work.
tmtomh
It looks like a full-height drive. I believe your LC will accept only half-height drives. Also, it's a micropolis, which means it's (a) old, ( B) probably very noisy, and © probably very unreliable.
Dog Cow
The power supply in the LC III might be too tiny to support such a high-capacity drive.
And that threw me off when you deleted your post.
JRL
I've been running a 9.1 GB 50-pin SCSI Seagate in my LC 475 for quite a while now, and it's been fine.
macgeek417
Would this one work w/ a 68-50 adaptor?
NEW Seagate 73GB Hard Drive - ST373207LW
SCSI Ultra320 - 320 Mbps - 10,000 RPM
Seagate Model / Part # ST373207LW
Capacity: 73GB
Rotational Speed: 10K
Seek Time: 4.7ms
Interface: U320 68-PIN SCSI
EDIT:
how about this one?
Detailed item info
Product Information
The Seagate Hawk 2LP 1.06 GB SCSI-2 Fast (8-bit) Hard Drive is fully compatible with PC systems.The Hard Drive connect by: SCSI-2 Fast (8-bit) for Internal utilization. Spinning up to 5400 RPM and offering capacity as large as 1.06 GB
Product MPN
MPN ST31230N
Key Features
Designation Desktop Computer
Capacity 1.06 GB
Interface SCSI
Enclosure Internal
HDD Form Factor 3.5" x 1/3H (Low Profile)
Spindle Speed 5400 RPM
Technical Features
External Data Transfer Rate 10 MBps
Seek Time 10.4 ms
Buffer Size 512 KB
Average Latency 5.56 ms
Interface (Detailed) SCSI-2 Fast (8-bit)
Other Features
Platform PC
Package Qty. 1
Dimensions
Height 0.99 in.
Width 4.02 in.
Depth 5.75 in.
Weight 1.54 lb.
JRL
#1 won't work, because I think you can't run an Ultra-320 drive on the LC's PSU. (power constraints, etc.)
#2 is too big to fit.
