chu-oh
Here's an update to a previous thread of mine in relation to getting a SCSI2SD booting with the Plus. The Plus is notorious for having a flaky/early version of scsi that doesn't work as expected and as far as I can tell there is no other reports of it working with the SCSI2SD.
So my previous attempts to make a bootable SCSI2SD drive with codesrc's tutorial (found here) on the Plus resulted in weird behaviour (clicking noises, resets etc). I found out through setting up the SCSI2SD as if it was a HD 20 (see this comment) and using an earlier unmodified version of the HD SC Setup (v7.1) I could install System 6.08/7.0 to the drive and boot from it. However this relies on access to either a way to easily make 800k disks, access to an original floppy with an early version of HD SC Setup or a floppy emu (in which case why would you bother with the SCSI2SD).
So for perpetuity's sake I've copied the driver partition that HD SC Setup created - this can be used in lieu of the ludo.img mentioned in codesrc's tutorial.
I've tested this with both the revision c rom and a Rominator (which I believe is based on the c revision), it would be great if someone with a Plus running an earlier rom version to give this a shot too.
View attachment Apple_Driver.img
