Temetka
So I've got my 450MHz AGP Sawtooth running.
However it is only recognizing 1GB of RAM.
According to LEM and everymac.com it will accept 2GB.
I have a 512MB and 3 256MB cards installed which should equal 1.25GB of RAM. No amount of moving modules / replacing chips gets it to recognize over 1GB of RAM. I have tried every slot, and every slot reads the RAM. However with all 4 slots filled, it will report 1 as empty and the other 3 as filled with the right size and speed being reported.
All RAM modules are PC133 and again, they all work but not all are recognized.
So I'm thinking either it's because I am using PC133 and not PC100 even though 133 will downclock just fine. Or it's a firmware issue. I have booted into Open Firmware and reset it a few times, pressed CUDA and even done the 3 fingered PRAM reset 3 times in a row.
Ideas, solutions?
The OS is 10.4.11
I have a 16MB Rage 128Pro AGP card and a Sonnet ATA/100 card installed. This is going to host files, be a backup for the iBook if I can get it running right. Thanks in advance.
Ideas, solutions?
The OS is 10.4.11
