techknight
Or find out if the RAM card interface has enough of the databus to contain a ROM/RAM card. Then you can run the appropriate jumper wires. IT would be universal at that point.
The Classic II, the RAM slot is actually a ROM expansion slot. So it would just be direct plug/play. The Classic 1, youll probably need a couple jumper wires.
