Resource Fork - Manual Parsing
Dennis Nedry
I'm working on figuring out how resource forks are parsed, somewhat for curiosity and also maybe for some use to somebody. I've made some progress, could anybody fill in some more info? I can't seem to find this online anywhere.
HEADER
0000 : 0003 Resource Raw Data Stating Location (= length of header)
0004 : 0007 Footer Starting Location
0008 : 000B Resource Raw Data Length
000C : 000F Resource Footer Length
RESOURCE DATA
Loop
4 bytes Length of resource data (x)
x bytes Resource data
End Loop
RESOURCE FOOTER
0x10 bytes Repeat of header data 0000:000F
0x0C bytes unknown
0x02 bytes 0-based count of resource types
loop
0x04 bytes 32-bit ASCII resource type
0x02 bytes 0-based quantity of this resource type (?)
0x02 bytes unknown (?)
end loop
loop
0x02 bytes resource ID number (16-bit)
0x02 bytes attributes (?)
0x04 bytes Offset to this specific resource data from raw data starting location
0x04 bytes attributes (?)
end loop
loop
0x01 byte resource name length (x)
x bytes ASCII resource name
end loop
dougg3
I'm pretty sure this is what you're looking for, courtesy of Inside Macintosh: Volume I:
Sorry about the flash lightening parts of the images!
basalgangster
Here is a little summary of information on page 128-131 of Volume 1 IM.
------- resource header ------
4 bytes Offset to Resource Data
4 bytes Offset to Resource Map
4 bytes Length of Resource Data
4 bytes Length of Resource Map
112 bytes - reserved
128 bytes - available for application-specific data
--------- start of resource data ------
----- for each resource -----------
4 bytes Length of Data
variable - actual data
---------- start of Resource Map ------
16 bytes copy of resource header
4 bytes Handle to next resource map
2 bytes File reference number
2 bytes Resource file attributes
2 bytes Offset to Type list (from beginning of resource map in bytes)
2 bytes Offset to Name List (as above)
------------- Type List --------
2 bytes Number of types -1
----- for each type there will be one of these ------
4 bytes Resource Type
2 bytes Number of this type -1
2 bytes Offset to Reference List for Type
Resource attributes:
bit 7 (reserved)
bit 6 resSysHeap
bit5 resPurgeable
bit 4 resLocked
bit 3 resProtected
bit 2 resPreload
bit 1 resChanged
bit 0 (reserved)
