cassette
New member
Hi Folks,
First post here on the forum after lurking for years, hopefully its not presumptuous leading with a request but I'm in a bit of a jam:
I've purchased this Seritek 1SM2 card, looking to use it with OS9, support is described as 'limited' but present nonetheless. No luck using the re-packaged drivers from the Seritek website or on the CD it comes with. I have been in correspondence with Firmtek trying different solutions and all existing Extensions seem corrupted by OS X repackaging.
I've gone through quite a few variations of dragging and dropping the 'SATAEnabler' file into the system folder. It often shows up as a nondescript PC File, or generic text document. There was one instance from one of the packages i found where the system folder recognized it and placed it into extensions, it loaded, but my card was still the generic grey box upon inserting it on reboot.
On the off chance someone else out there might have them, thought i'd post this message.
Any words of wisdom would be great.
thanks!
thanks!
