AlpineRaven
This Nubus card is Radius PrecisionColor Pro 24AC 24bit from 1993.
I would've thought It'll suit Quadra 840av due its age/1993 era so decided to put it in & try it out.
Downloaded the Radius software from Macintosh Garden (from Gambia Site has dead links)
I would've thought this video card would be accelerated/faster than factory's monitor port, while I was using the 840av it felt sluggish compared to standard monitor port!
So I decided to do benchmark testing - you will see one right down the bottom and highlighted is massive drop in performance. Yes I did test it in 256 colours.
Am I missing something?
Cheers
AP
Cheers
AP
