Hello,
I have some problems getting a mouse working on a Apple IIGS.
The keyboard has two adb connectors one to the left, another to the right.
First I notice that if I connect the keyboard to the cpu with the left connector it works. He dont work if I use the right connector.
Its my first contact with a IIGS so I say to me its strange but okay...
Then I connect a mouse (works well on my Powerbook 100), of course to the right adb connector. The mouse work (move if I move it) but also do over reaction and erratic movements and is unusable.
The reverse configuration (uc to the the right adb and mouse to the left abd) give no result. Nothing works, mouse and keyboard.
Last : the mouse alone one the cpu adb port is working well.
I assume the problem is in the keyboard.
I check the continuity of flexible links of the two adb daughter boards and everything look good.
Any idea of what can I check now to try to find the problem ?
Thanks and regards.
Philippe
Thanks and regards.
Philippe
