A majority of Blue/White G3 Towers wont do Slave Drives either, it depends on what ROM version is on the machine.Even the Beige G3 didn't support slave drives until the Rev. B ROM.
It is literally a broken chip on the board, not a ROM issue, that prevents early B&Ws from running a slave drive properly. The UDMA/33 IDE ports in those boxes are run by an add-on IDE controller by CMD and the rev used on the early boards has a hardware issue that causes corruption. Any B&W that has an internal drive bracket that can take two drives *should* have the updated chip.So it is something to do with the ROM, whether in the IDE Section or the main section remains to be seen. But for some reason Apple sold these machines with a cable that can handle 2 drives and mounting hardware for a second drive. I'm guessing that there is a firmware update that can fix this "issue" and one can have 2 IDE Drives on a G4 Tower of that vintage.
Most of them have a Master/Slave Jumper for the cards with no jumper being Cable select like on an IDE Drive. Some just have 1 jumper for both cards (where one becomes master and the other becomes slave) and others have a M/S jumper on both sides.Yes, but did they present both cards together as one volume (JBOD), or as master/slave?
Because the IDE controller on the 68k Macs doesn't implement master/slave. As has been covered multiple times in this thread.it fails on the Mac but works on the PC. WHY?!!!
