QS G4 USB Overdraw Warning
LaPorta
I am getting this message on my G4 every time I start it up. I have no way to reliably figure out what is causing it, short of pulling everything out. As far as USB, I have the keyboard/mouse, as well as an iSub connected to the internal 1.1 ports. I have a PCI USB 2.0 card installed, and all that is in there is a joystick, and a 4-port USB hub that currently has one Gravis GamePad Pro connected to it.
I can't find anymore info in the System Profiler or anything. Would the Console be able to give me more info somewhere?
Nixontheknight
use a USB-Y cable until you can figure out what is causing it
It will be a built in port, not one on the card, and I think, once it has happened, the port won't work until it gets a chance to reset? Or am I misremembering.
I'd start by unplugging everything and plugging them back in one at a time after a reboot watching for the message. Any other way isn't easier and it might clear the fault.
You probably have a short somewhere.
Don't forget that sometimes there are ports inside the case. Make sure nothing metal is leaning against the or the logic board.
LaPorta
I'll give that look and see...if I can rule out the card, that helps right there.
LaPorta
Plot thickens: I wound up unplugging literally everything from USB...still got the warning. So, on an educated guess, I remembered that the two USB ports on the ADC display never really worked properly. So, I restarted, and unplugged and plugged the monitor back in....and the message was duplicated. I guess I will try a separate monitor to see if it is the video card itself or the monitor. What a strange error.
LaPorta
Yeah, it's the monitor. I hooked a DVI-VGA adapter to the Radeon 9000, got my Dell 17" on there. When I started with just the Dell, there was no message or warning. Once I hooked up the Cinema Display via ADC, warning immediately came back. The USB ports on the display also do not function.
So...do I have a malfunctioning USB system in the monitor? Or, do I have some sort of failing G4 PSU that cannot meet the demands of the monitor?
halkyardo
For what it’s worth, I have an ADC Cinema Display that’s always had a similar problem. Sometimes the ports work, sometimes they just never get recognized, sometimes they cause an overcurrent warning. Even happens when plugged into a non-Mac via the big DVI adapter brick.
I’ve taken to just leaving the USB part of the adapter cable disconnected, but I suppose that’s not quite so do-able when connected directly through ADC!
