Powermac G4 Identity Crisis
belgaonkar
Picked up this 400MHz "PCI" Powermac G4. System profiler says this is a "Powermac G3" but it is in a G4 case with a G4 processor. Not sure what this thing is. Did apple just not bother to change the system Id?
Sorry about the image. Guess it's not my lucky day.
bunnspecial
The Yikes!(PCI graphics) identifies in system profiler as a PowerMac G3.
In truth, it is a B&W G3 in a different colored case with a G4 processor and no ADB port. In fact, if you look at the LoBo, it has the solder pads for the ADB port.
It raised my eyebrows on the first one I bought, but it's 100% correct for that generation G4.
LightBulbFun
just reading the system Profiler Rev 2.6 G4... do you mind taking the heatsink off and grabbing a picture of the CPU for me please? in regards to the system profiler shot as bunn says its completely normal just a fun little "typo" apple left :)
belgaonkar
Hmm, the "warranty void if removed" sticker did look familiar.
I have attached images of the cpu.
bunnspecial
Yes, the Sawtooth and following are totally different internally and also eliminate the handy bus/multiplier jumper block.
One interesting thing about these compared to the B&W is the heatsink. Unlike the flat and squat B&W heatsink, these look a lot like a mini Sawtooth heatsink.
LightBulbFun
thanks for the Shots :) looks like your CPU was made week 41 1999 I also see you have what looks like a Radeon 9200 Mac edition fitted :)
indeed you can over clock the BW G3
belgaonkar
Hmm just noticed that its got a 9200. Will probably sell it as I have no intention (yet) of using this machine. If I ever do, Ive got plenty of spare PM G4 graphics cards on hand.
EvieSigma
Young ThinkPad Apprentice
Darn, mine is a 350 so I'd only get up to 400. :(
I've had zero luck trying to find a faster CPU out of a Yikes and any accelerators I find are phenomenally expensive.
bunnspecial
Is it possible to add the ADB port back on and have it work?
Never tried it, but I don't see why not.
You'd also have to knock out the place for it. I don't remember offhand if it's stamped into the case or not, but I expect it is.
With that said, if you need/want ADB and a G4 you're better off with an upgraded B&W IMO.
Also, I love my ADB peripherals, but the one significant need I see for a real ADB port(as opposed to USB) is for a software HASP. AFAIK, all of the software I have that needs an ADB HASP can't use Altivec so a fast G3 is usually as good as a G4.
