PowerMac G3 Server - Need help Identifying 2 components on the Logic Board 820-0991-B
JohnnyPhantom
Hey Everyone,
I was given a PowerMac G3 Server, and it was working, then it just stopped. This is totally my fault and I've been kicking myself. When I was given it, I was told the battery was removed, so I took it, put it on my desk and it powered up just fine, about a hour later it no longer powered on. Weird, I opened it up and saw not only a battery was inside with its brown ooze crusted all over, but the insides were now wet with a clear liquid. I took the board out and cleaned it very well and soaked it in rubbing alcohol. I let it dry for days, and now it powers up again. However, it no longer has a startup tone or video. I just get the power LED and the fans spinning. I'm working with Luke over at Console5 to make a cap kit for this machine (incase the caps are the issue) but underneath the battery are 2 components, what looks like a resistor and a capacitor and I have no idea of their values. C241 and R151. Would anyone happen to know what I can replace these with? The board is numbered 820-0991-B
Thanks Everyone!
Hey Everyone,
Thanks Everyone!
First thing I would do is void that warranty. Remove the jumper block and clean the contacts in there.
The cap and resistor are probably okish. A better photo would tell us what the resistor is, the value is written on it but your photo is fuzzy.
JohnnyPhantom
Thanks for the reply! This is about as close of a photo as I could get, looks like a 101 on the resistor not sure on the cap if there's anything at all.
But if I remove my warranty sticker, will apple still repair the machine? I'm sure there must be some AppleCare left on it :p
Looks like 101 as you say that means it is a 100ohm Resistor. The numbers work as all but the last number are significant figures, and the last is the number of trailing zeros. So for yours, it is 10 and 1 zero, i.e. 100.
Caps are rarely labelled.
