Powerbook G4 (DVI): USB2.0 card recommendations
tomlee59
Although I use FW most of the time, high(er)-speed USB is getting to be a real need. USB 2.0 cards abound around here. Are there any that are particularly good (or, conversely, so bad that they should be avoided)? I see no shortage of on-line opinions elsewhere, but I rather trust the folks here for more useful recommendations.
Byrd
Any generic OHCI compatible USB 2.0 card will work; in fact all the vanilla cards I've put into my PB G4 867 have been detected right out of the box under OS X.
JB
tomlee59
Thanks, Byrd -- it's good to know that you haven't had any bad experiences. I see generic cards around here for $5-10 pretty regularly. At those prices, I should just try one. If it doesn't work, it can always serve as a nice anatomy lesson...
Franklinstein
I've heard that those cards based on NEC chipsets have the best performance and compatibility under OS X. I'm using an Adaptec AUA-1420A, (NEC-based) and have had no problems with it. It even has a nifty plug for a power adapter for supplying juice to devices requiring in excess of 500mA (such as bus-powered 2.5" hard drives, etc).
I use it in every PowerBook (from 2400c to original G4) that requires either USB 2.0 speeds, or USB capabilities period. It even works under OS 9.
tomlee59
Thanks for that recommendation -- an external power jack is a definite plus. I'm sure I can dig up an Adaptec around these parts. Now I know what to look out for.
Thanks again!
