PowerBook 3400c Repair Stories
raoulduke
Yeah I've noticed that too.  Salvaged one for the 3400c I think, but not for the Kanga.  So it's not recurring corrosion from that in this case.  Look I don't know.  Hopefully yours comes out fine, but I don't think it's worth the risk - particularly since who really cares about PRAM batteries (especially now).
Is there a way to totally bypass the SCSI bus on boot and force it to ATA?  I tried forcing to SCSI ID and holding down mouse button [both via internal key/track, bc it doesn't seem to recognize ADB keys] to no effect.
I'll take a look at where the traces from the ATA bus are coming from.  Weirdly despite the symptoms, it clearly is an ATA bus problem - who (who knows more about this than I) knows how the ATA bus initially interacts - like what's the process, and what would be missing (signal-wise ?) that would cause it to fail to be recognized, but then later recognized once the SCSI bus powers up?
MikeatOSX
Did anybody solder a new backlight lamp into a PowerBook 3400c display? I have two pieces of them, a soldering station and some soldering experience.
Is it easy or hard?
Syntho
I have a 3400c that seems dead. It started when I'd boot it up and there was the typical white screen, but without the cursor. It never moved past there. Now it won't boot or get power at all. No chime or anything. There's a new PRAM battery in it so I don't think that's the problem. Maybe the motherboard is corroded from the old one though? I reset the power manager using the reset button on the back, unplugged it, tried everything.
Syntho
Turns out, the power board wasn't seated securely. I pushed it in, booted up and got the cursor and question mark (new HD). I thought all was well so I turned it off, put it back together and tried booting up, only to get a white screen. I've disassembled the whole thing, taking cables, pram batteries and ram boards out piece by piece to see what the culprit is, but I only get a white screen every time. There's got to be some simple thing going on here that I'm not aware of.
Syntho
Looks like it’s going to stay frozen with a white screen and cursor at the top left. It won’t move. I did get it to show the blinking question mark a time or two but usually it’s just a frozen cursor at the top left. Anyone have any ideas? I might just use this one for parts if it’s too much trouble to repair.
Syntho
More info: it powers up, I hear the chime, the HD spinning up, and it goes to a white/grey screen. Sometimes it'll go as far as having the cursor frozen on the top left, and oddly, sometimes it'll go to the disk icon with a ? while the cursor is still frozen. I'm not sure about this but I think taking out the ADB ribbon cable helps the disk icon show up more often. When I have an adb mouse plugged into it, the cursor still doesn't move. I have a good, working HD in it (tried multiple) but that doesn't seem to have an effect. At one time i thought I smelled burnt plastic/smoke coming from it after installing a new PRAM battery and HD, but it may have just been my imagination.
The logic board actually looks good. No corrosion or anything. The PRAM battery was still good, but I switched it out anyway. In fact, that's when this all happened: when switching the HD and PRAM battery. I switch back and forth between the old and new HDs and batteries but that doesn't seem to have any effect. Is it at all possible that the PRAM battery I put into it, or the new HD (actually an ATA SD card adapter) has somehow fried something on the board? It was working fine before all of this, but now it's dying a slow death. The problem started right after switching out the aforementioned parts. A few times after getting the white/grey screen after switching those out, I seem to have disconnected the little power board out of its socket by mistake which caused it to not boot at all. After figuring that out I pushed it back in, but it went right back to the grey screen problem. I didn't do anything out of the ordinary on it or damage it either. I've done this exact sequence of switching out the PRAM battery and HD on another 3400 and it worked flawlessly and runs fine.
I'm thinking it's best to just gut it and use it for parts. If someone can come up with a simple fix I'll see what I can do, but I don't have too much time to keep running diagnostics. I'll just look for another one that's working :)
Jinnai
I had a Classic II that booted to a gray screen and the issue was either RAM or a dirty motherboard, I'm not sure. Is there any chance the issue is caps? I only know about caps so... I hope you can figure out the issue.
CC_333
Jinnai might be on to something. If it has a RAM card, you might try removing it. Or did you already try that?
c
Papichulo
I found this in my powerbook 3400c and there was a little leakage on a board but i cleaned it with water. This is what was leaking. Really bad. If it wasnt for this website i wouldnt of known to  remove the pram battery!20190912_233822.jpg
MikeatOSX
After 4 years (I had a personal tragedy in the meantime) I got out all my 3400c, Kangas and 5300.
Omg, only 1 of them was working again.  :disapprove:
A PB 3400c survived and I put in a mSata SSD and installed all volumes new.
When I nearly finished this after some days, the 3400c showed a strange behavour:
Errors when copying files, unwanted newstarts and more. And getting hot on the left side of the bay (where the mSata sits).
I thought there was something wrong with the mSata and tried CF adapters and harddisks.
A complete wrong idea:
It was the power supply board and nothing more. I removed all connections and connected one after another and it turned out, when the power supply board was overburdened the 3400c did not start.
I had a spare ps board and after putting it in the 3400c started immediately.
But only for some hours.
So I have to refurbish several power supply boards.
Any ideas what I should do first with them? Only put in new [SIZE=12pt]capacitors?[/SIZE]
Syntho
Two and a half years later, I pulled out my old 3400c and I STILL have a white screen. I get a chime and the screen comes on, but it stays at that white screen no matter what I do. HALP.
