avadondragon
Are any of the passive matrix LCDs in these powerbooks interchangeable?
This is something I've been meaning to investigate, whether or not it was the on-board graphics or the displays themselves that limited greyscale depth.
There were three different displays used (with corresponding inverter boards) - Rev A (Sharp LM64P51), B (Hitachi LMG5200XTFC), and C (Sharp LM64P58 / Sharp LM64P582). It seems 140/145/145B can use any of the screens, according to various Apple docs - and certainly you see the Rev C screen used in many 140/145/145B's out there.
The Rev B display is different than the other two, with a different display cable and inverter board, and relatively rare; US Apple techs weren't even allowed to replace them with the same part but rather with the Rev C kit instead.
160/165 are *associated* in the repair / maintenance docs only with the Rev C screen. The Rev A and C screens have the same display cable (they have the same Apple PN), same capacitors, but have different inverter boards... however, you do see these displays and boards mixed in the wild.
I haven't been able to find spec sheets on any of these displays to confirm whether or not the Rev A or B screens are in fact strictly 1 bit. When I put a Rev C display (and its corresponding inverter board) in, say, a 145, I only get 1 bit display options, which stands to reason. What I haven't done yet is put a Rev A or B screen in a 160/165 to see if the display limits output, or see what happens. It's on my to-do list.
Indeed, I had a 145 and the LCD worked in my 165, including in 4-bit greyscale. The part number was a bit different though - it might have been a Rev B.145, 145B (both Rev C), 160, 165 screens are all the same. See this myoldmac list.
Has anyone successfully ordered from here for a PB160?I found a fairly reasonably priced source for these LCDs - $66
https://www.yoycart.com/Product/574060630467/
or
https://www.yoycart.com/Product/528329894933/
