Power Mac 7500
ExplorerZ
This is my first time dealing with a Power Mac. Power supply has issues half of the time. It only turns on when this is unplugged. Tried removing cards. No change. Ordering a compatible monitor to test the display. (No chime) Guessing it needs to be recapped.IMG_1299.jpeg
joshc
The 7500 has a lot of sockets/slots, so it's important to understand what each is for.
The power connector you have disconnected is the 3.3V power for the CPU - you're not going to get far without that connected.
Do you have a multimeter? Use it to test the voltages from the power supply with the machine on. It could be the power supply which is at fault.
However...
In your picture above, the cache is missing - did it come without it or did you remove it?
You are also missing VRAM. I don't think there is onboard VRAM so you need that installed as well.
You have a lot of memory installed so the memory test will take some time to complete when you power the machine on.
Can you show us photos of both sides of the CPU card? Including the part numbers.
Not having a cache will heavily degrade performance, but not stop the computer working. If you have a G3 or G4 upgrade, you don't need the cache anyway.
Not having any VRAM in that board means the onboard video won't work. I think they came with two 1MB sticks as stock. It might work with just one (because the 7200 sort of did... in a way... kind of).
Also, you have a huge amount of RAM in there. I'd remove all but one until you have it chiming and getting to the flashing question mark or the happy mac.
ExplorerZ
Lots of photosIMG_1316.jpegIMG_1317.jpegIMG_1320.jpegIMG_1319.jpegIMG_1311.jpegIMG_1313.jpegIMG_1310.jpegIMG_1314.jpegIMG_1313.jpeg
OK, your 7500 has a G3 upgrade and an ATI Mach64 Graphics card. You don't need a cache. Onboard video won't work, but that card probably will.
That is a tricked out machine.
Your issue might be that someone has fiddled with the dip switches on the processor. Can you photograph them so I can see how they are set?
ExplorerZ
ExplorerZ
It now powers on with cpu power. No chime. Cannot test display as my Mac to vga adapter has not arrived and it is not compatible with my LC monitor.
What you've done is slowed the processor down. We can work out how fast to run it later, but sometimes people knock the switches, or set them too fast. Setting it to a slower speed is a good trouble shooting start.
Boot first, speed later :)
