PM G4 ATA question
bizzle
Can you connect a hard drive to the second ata plug on the optical drive cable?
I used to on my graphite. Just make sure the jumpers are set correctly. The bus is slower, so don't boot from that drive.
Christopher
Well I just threw in a 27GB WD on there and it worked without a hitch, even without jumpers!
Thanks for the reassurance guys. I tried this before and it didn't work but I found out the cable was bad.
