Interesting, Ive seen almost that same picture listed as an SE/30 Pivot (presumably Greyscale) interface card. I just got one from macmetex along with one for the Color Pivot that has exactly the same connector. I haven't found my Radius SE FPD Card and cable as yet (found the "Magic Bus" adapter though) but I'm looking for it. If the SE FPD card has the same cable header, that'll be a VERY good place to start.
I believe that the low profile cards for SE/30 and IIsi are very likely to be identical, with only the backplane plate/cable length to differentiate them.
I'm still 43.2% asleep, more info to be posted after my coffee kicks in . . .
< three cups of coffee later later: he re-posts reply in the thread on the proper website . . . DUH!! . . . :-/ >
Pivot_SE/30_front
to be continued . . . the grlf is restless and I'm going into
fecal avoidance mode! 8-o
Back again! :approve: Well, the first pic I linked to from 'fritter proves my guess wrong, however my 1992 ROM, 1990 PCB copyright Color Pivot Card says:
PIVOT O3O DIRECT SLOT INTERFACE and has the same 15 pin header/shroud for the cable as does my
PIVOT IIsi INTERFACE 1990 copyrighted card that seems identical to the one in your pic. Mine has a full ROM covering label that says:
CLR/PVT V 2.6
The 'fritter image of my
Radius_FPD_SE card, shows a 10 pin 9 signal, keyed/unshrouded header for the cable, so if I or anyone else can buz
that connector out, we'll have a starting point! Hopefully someone else will come up with the real deal and save us the (guess)work!
I don't see any reason why you can't use the IIsi Color Pivot card as the bottom card in a
gamba'd SE/30!
I'll post pics of my cards soon, I just ordered a second IIsi card as backup. I'll be desoldering the connectors of one of the Color Pivot Cards and one of my '030 Slot Ethernet cards to splay them out across the bottom of my IIsi's MoBo in another
sub-basement approach hack.
I'm shooting for a (non-pivoting) Color Monitor sitting next to my IIsi with my APD sitting on top, running off the MoBo Video, happily in 8 bit greyscale mode as it's doing right now under 7.5.1. Hopefully, I can knock the OS back to runing the whole shebang under 7.0.1 (with the Tune-Up) installed on a low profile SCSI II Drive.
That'll leave
plenty of room for a
NuBus Adapter Card above the deck, sporting my
Radius Rocket 33 and a, one day to be acquired, SCSI II Daughtercard.
My lowly 'lil IIsi will be ready to kick some serious SE/30 @$$! }
