Performa 6400 Memory Type
LC_575
What sort of memory does the Performa 6400 use? My PC100 modules refuse to fit yet have the right # of notches.
waynestewart
Don't try PC100 RAM I accidentally used one in a 6400. It arced and destroyed the socket.
You should be using 168 pin 5volt FPM DIMMs
bibilit
Not sure, as should be 5 volt and not 3.3 volt.
you probably can ask to the seller first.
LC_575
Just asked the ebay seller if they're 5v or 3.3v. If they're 5v, then they'll be fine for the Performa right?
