Performa 6214CD not outputting video to a VGA screen.
joshc
Don't forget that the 6200 series will display nothing if a dead PRAM battery is installed, test it with a multimeter to make sure it is near 3.6 volts.
Not true. My 6200 has had a dead PRAM battery since I got it, and it works perfectly fine.
I hear that myth a lot, especially in relation to the 4400. LEM says a 4400 can't boot with a dead PRAM - mine booted fine with the PRAM disconnected.
LCGuy
LC Doctor/Hot Rodder
My 6200 came to me with a dead PRAM battery, which I removed, and its never skipped a beat. I think the myth comes from the 6100, which shares a similar model number, and does suffer from the problem.
Outlander
Not really a myth. Back in the day when these boxes and the 6100 alike was top of the line, several varieties of macs would not boot up with a dead cmos battery installed. Especially if the unit was unplugged from the wall. The power supply on sensing models(no on/off button) will keep the system clock going and the battery is not needed so long as the power from the wall is not interrupted. Once the unit is unplugged for a few minutes thou, it will often fail to show any video. The 6100, and other models that used an on/off switch relied solely on the cmos battery to keep the pram alive and the clock active, so these units would simply not show any video after the chime unless, like was said earlier, a double tap on the power button was used, or a new battery was installed.
Heh, we use to get so many free macs back then because people failed to realize that the unit required a cmos battery. Half the reason I have so many old world units in storage because people would just abandon them, pop in a $15.00 battery and wala! But yes, some units will boot with no cmos battery installed, just how it goes I guess, it's been so long since I worked on these boxes with system 7, the good old days.
