benjgvps
On June 2 I got my computer parts I ordered for my PC from btecanada.com: XFX branded Nvidia Geforce FX 5200 (128 MB), Socket 775 3.4 GHz P4, Cheap foxconn motherboard (No SATA, DDR2, Core 2 duo support, PCI-E) with AGP, 3 PCI, DDR 400, Socket 755, (Huge) CPU fan.
I bought these cheaply so I couuld play Team Fortress 2 and Counter Strike: Source on my PC and not have to use the family Dell 4600 (With snorton internet false-sense-of-security). Everything is quite fast though the install was painful... I had to remove the grille on the PSU to make it actully fit, and then put in the screws to keep the fan in place... I also had a hard time getting the sound and Ethernat working, later found out that it was me putting the settings on "Failsafe" when trying to get Windows XP working.
Overall it was a good and I really LOVE the feature that you can load a Windows app on to your computer and change the BIOS boot logo. Right now I have it set to the Half Life 2 log, Working on the classic apple or the logo for Portal (Cake FTW!!!). I will be buying a new motherboard eventully with new RAM, new video card and new PSU.
MOTHERBOARD ADVICE NEEDED: I cannot for the lif of me find a motherboard with these requirements and be under $55: DDR2, PCI-E x16, 3 PCI, TWO IDE sockets (IS THIS TOO MUCH TO ASK!), and SATA.
