My Powerbook 180 restoration continues apace. I recently replaced the ancient spinny drive with an RP2040 based ZuluSCSI from rabbit hole (https://store.rabbitholecomputing.c...-2-5-inch-p/zuluscsi-rp2040-laptop-2.5-in.htm). Got it up and running without too much trouble, and installed System 7.1. Everything seemed ok, but it appears that whenever the computer puts the display / drive to sleep, the drive doesn't wake back up again. The mouse still works etc, but if I try to navigate to finder or do just about anything it hangs and I have to power off and on.
Has anyone else run into this issue? Are there and specific zuluscsi.ini settings I need to add for Powerbook sleeping to work properly?
Thanks!
-Charlie
Thanks!
-Charlie
