Painting the metal case of a Quadra 800/840av
bigD
I thought I'd touch up the metal portion of the case on one of my 840av's (it's pretty scratched up), and was curious if anyone knew of a spray paint that matches the original color closely? All the spray paint I've been able to find seems to be a much darker shade of gray.
Thanks!
System7
Banned
You should be able to take it to a paint store, and they should have a color analyzer. Then you will know the color.
