OS 8.1, Startup Items and the Launcher
l008com
I never ever used the Launcher control panel back in the day, but after many years of OS X, I unsurprisingly find the Launcher pretty useful these days.
So I loaded up the launcher with all the apps I use the most, my plan being to do this on every Mac OS version/volume on this Machine. But I want the Launcher to open on boot. So I put an alias of the Launcher into the Startup Items folder.
This should work, right? It's been a while since I used OS 8 as my primary OS, but I have lots of old years on classic OS, and that's how it's supposed to work. Here's what DOES happen. Whenever I have a Launcher alias in my Startup Items folder, and I boot up the Mac, that alias disappears and it does it before it opens it. So every time it starts up, the startup items folder is empty.
Now I tried putting a text file in the Startup Items folder, and that opens on boot no problem. Then I moved it out of the folder, and put an alias of the text file in the Startup Items folder, and that also opens right up on boot no problem. But when I put an alias to a text file AND an alias to the Launcher, and reboot, the text file opens and the Launcher alias is gone yet again.
Anyone know what's up with this?
Elfen
Launcher, as I remember it, was a control panel. Pat of the control panel parameters was to start at start up.
Another parameter was where it's launch folder is at, this is where you put aliases of programs, folders and files into to limit the access to your machine.
Launcher was great for young kids and schools, not necessarily teens and adults. Most of the time I disabled it at the schools I worked for and taught the kids how to go about the desktop and find the programs they need to use.
l008com
Ok looks like I got this all worked out. You cannot manually put an alias to the Launcher control panel in the Startup Items folder. Instead, you have to select "Show Launcher as Startup" in the General control panel. That will cause the Launcher to auto-open and keep auto-opening. It's very handy.
