Openfirmware and Pismo
jimjamyahauk
Hi All,
I've been delving around in open firmware on my Pismo to see if I can control the internal fan, or at least set a better temp. for it to come on at.
In the device tree I've found the via-pmu, and under this is a node called 'power-mgt'. A property of this is called 'thermal-info'. As far as I know this must be related to the temp sensor in the Pismo because the G4 chip I have in it doesn't have the thermal assist temp diode on the chip enabled.
To check that this was specific to the Pismo I found the same 'power-mgt' property on a Digital Audio G4, which had everything listed the same, apart from the 'thermal-info', which was missing.
I've now hit a problem. There are 4 values of data encoded in open firmware for the 'thermal-info'. I believe they are the limits for the fan, as they do not change from boot up to when the computer is definitely toasty.
I can write one value by using the following command:
Code:
12345678 encode-int " thermal-info" property
However, I need to be able to write all 4 values - and I don't know the open firmware commands to do this... could anyone help?
Thanks (and sorry for the rambling post),
James.
jimjamyahauk
Using OF commands, after amending the settings for thermal-info I got the fan to turn on straight after booting, by setting them to 01010200 00000000 01010200 00000000.
With the open firmware dump below of the values for via-pmu / power-mgt could anyone explain what the values present could likely be. i.e. are the set of 4 hex values likely to be 2 sets of values, or 4 separate ones?
I decoded each of the hex values and got 16843264 for hex 01010200 and 1213468963 for hex 48434843. I think these refer to temperature values (perhaps F?).
Code:
ff918050: /pci@f2000000/mac-io@17/via-pmu@16000/power-mgt
compatible              7669612d 706d752d 393900.. ........  "via-pmu-99"
device_type            706f7765 722d6d67 7400.... ........  "power-mgt"
max-aux-power          00000000 ........ ........ ........  ....
name                    706f7765 722d6d67 7400.... ........  "power-mgt"
prim-info              000000ff 00000060 00003e80 00017fb5  .......`..>.....
           0010:      0000d607 00000000 00021300 46000220  ............F..
           0020:      101400.. ........ ........ ........  ...
registry-name          65787469 6e742d67 70696f31 00......  extint-gpio1.
thermal-info            01010200 00000000 48434843 00000000  ........HCHC....
Any knowledge people may have on this and Open Firmware properties would be much appreciated.
Thanks,
James.
