*Yawn* I'm not interested...
Seriously though I'm glad they ditched it, it never worked very well to start with. No application that requires an OS 9 environment requires more than mid-range G4 PowerMac to perform optimally, and they are cheap and easy to find, so buy one and install OS9 if you need it. Or maybe you should get off your ass and see if you can replace the software that's got you attached to an OS that's been dead for 4 years (arguably long) with another or a combination of other OS X compatible apps.
If OS 9 support is the *only* thing to a PowerPC user upgrading to Leopard then that's really quite bad.
