Need help Iding cards.
crazyben
And the card works. Thank you help on this.
I have xceed Se/306-48 card that I get signal but no clear picture. Do you have experience with that?
halkyardo
Glad to hear it! One thing to be aware of with it, that I don't think I directly mentioned - it can't tell whether or not a monitor is connected, and the SE/30 seems to default to using it as the main display and the internal display as the secondary. So if you've got the card installed, you've basically got to keep a monitor attached to it, otherwise your mouse cursor is liable to disappear off-screen.
Never had one of those, sorry!
crazyben
I did notice that. When I had card installed it will default to monitor and if the monitor was not plugged nothing will display SE screen. I was not able to move the cursor to second screen. Is it possible to use dual screen with this card?
halkyardo
Yes, definitely! Open the Monitors control panel, and you can drag the two displays around to match the layout on your desk. I think you have to click each display at least once to make them both active.
You can drag the tiny menu bar to choose which display has the menu bar on it, and if you hold down Option, a little Happy Mac icon appears - dragging that to one monitor or another sets which one is considered the “main” display.
crazyben
Wow nice. I will try that. Thank you.
