Need help getting IIgs to work
ken27238
Just got a apple IIgs today and I am going to need some help with it since this is my first apple II.
I got it plugged it in to the monitor that I got too ( apple IIc green screen) and also the floppy drive keyboard and mouse flipped the switch on the back and the light turned on for a second and the blipped off. nothing else.
I opened it up and there are no cards in it just the board and the power supply.
Any ideas or am i missing something big here?
david__schmidt
Unplug everything but the monitor and the power. Take a good look at the power supply - is it rated for 110VAC? Does it turn on for any longer length of time without any peripherals attached?
Charlieman
Have you tried playing with an emulator first? This online one can be tried without installing (much) on your modern Mac or PC:
http://www.virtualapple.org/
Check out manuals online for the keystrokes to reset the IIgs and access the built-in control panel.
ken27238
so I changed the battery and it stays on for a fraction of a second longer but it still turns off
david__schmidt
Either the power supply is bad or there's an electrical short in the machine somewhere. Start by pulling every single thing that's plugged into it, out. All cards, all cords, everything but the power. If it still doesn't work - it's most likely the power supply.
ken27238
yea its the power supply.. when I turn it off I hear a click from it....Luckly I'm going to be getting another IIgs :D
Dog Cow
The clicking is the sound of the oscillator frequency dropping in to the audible range. The power supply has some safety features, such as disabling power when it detects a no-load condition (ie, when the power supply isn't plugged into the main board).
ken27238
the power supply is plugged int the main board
Dog Cow
I'm just
OK. Well now you know what to listen for when it's not. :-/
